Alloy drilling and planetary direct drive
02/09/2026 at 23:49 • 0 comments![]()
I am in the process of using the lathe to get flat surfaces, then pilot drill all holes and fabricate a hole saw type tool to cut the oring grooves in the alloy.
I have made a 3d Printed planetary Direct drive motor holder with D drive for thr rotor shaft.
Graeme
