etyper_print_in_place_v3.stl
Improvements of the previous version as well spacing for the gpio pins if you want to go with an angled connector to avoid soldering - print in material of your choice, no support required
Standard Tesselated Geometry - 368.05 kB - 02/28/2026 at 19:34
Download
etyper_body_v3.stl
If you prefer to print in separate parts, easy assembly.
Standard Tesselated Geometry - 722.35 kB - 02/28/2026 at 19:33
Download
etyper_arm_left_v3.stl
If you prefer to print in separate parts, easy assembly. Minimal support required, current version more difficult to print than print in place.
Standard Tesselated Geometry - 273.71 kB - 02/28/2026 at 19:33
Download
etyper_arm_right_v3.stl
Download
