Battery cable reel
an hour ago • 0 commentsAt the back side I created a cable reel out of two angled header pins, it works out pretty well. Makes it easy to store away the 9V battery cable when the Super Breadboard 2 is powered by USB-C (or by an attached 8-bit Workbench).
New prototype arrives
04/10/2026 at 08:00 • 0 commentsThe next-release prototype board arrived!
Going to test the new features, like the USB-C connector, 9-volt battery input and logic probe support (left or right hand side connector). The new kits are going to be partly pre-assembled, all the small parts will be on the PCB already. Will try to keep the price close to (or the same as) the previous version.
Improvements
03/17/2026 at 08:18 • 0 commentsCurrently designing the following improvements:
- Move to USB-C (still with breakout).
- Logic Probe support (will be also available as a kit).
- Power ON/OFF with a slide switch.
- Support battery power (6.5 - 12 V).
- All in the same compact form factor.
Any ideas? Let me know!
