1Install Docker and create user permissions
Docker Engine: If not already installed, follow the platform-relevant install instructions here: https://docs.docker.com/engine/install/
Docker user permissions: Ensure your user is added to the docker group (log out/in for changes to take effect):
sudo groupadd docker sudo usermod -aG docker $USER
2Enable "Third-Party Compatibility" in the Tapo app (if not using Kasa)
In the Tapo app, open the account (“Me”) page, navigate to “Third-Party Services”, and ensure that “Third-Party Compatibility” is enabled.
3Clone the repository
Clone the repository to your device:
git clone https://github.com/cjastone/tplink-powerdash.git
4Configure secrets
There are six files under
/secretsthat can be updated; these contain placeholder values only. These are only required when you rundocker composeand can be deleted once the container has been fully deployed. Recreate them should you need to re-deploy the container.InfluxDB's token format is undocumented but appears to accept a base64 string (except using _ and - instead of / and +) up to 88 characters long. Keep the stock token for testing or update if running long-term. If you update the token, it must also be updated in
/provisioning/datasources/influxdb.yaml. -
5Deploy the container
Deploy the container:
docker compose up -d
6Give it a sec!
Deployment time varies; should be under 30 seconds with relatively modern hardware and a fast connection to pull the images, or up to several minutes on heavily constrained hardware.
Once docker compose is finished, wait a few moments for services to start. Optionally watch for issues via
docker logs -f telemetry-logger. Initial errors while services are initialising are expected; it will keep retrying until the database exists. -
7Open the dashboard
If all went to plan, you should be able to browse to Grafana at
http://your.docker.host:3000and log in using the credentials previously configured under/secrets. Data should be visible immediately.
Ignorant of Things
