Pre amplifier
Transformer T1
- BN43-2402
- Primary: 14 Turns
- Secondary: 1 + 1 Turns
Transformer T2
To drive a 50 Ohm antenna or 50 Ohm band pass filter:
- BN43-2402
- Primary: 12 Turns
- Secondary: 8 + 8 Turns
To drive a final stage with MOSFETs the Turns are those of the following schematic, i.e.:
- BN43-2402
- Primary: 2+2 Turns
- Secondary: 3 Turns
10 W amplifier
To obtain 10 Watts from 1 to 14 MHz and 5 Watts at 21 and 28 MHz I added 2 x RD16HHF1 in push pull.
- some gate polarization (especially at 21 and 28 MHz) to work in class AB to be set by two potentiometers
- a command to set such polarization only when transmitting to avoid useless heating and power consumption
Low pass filters.
In both cases the output is more or less a square wave and it needs to be filtered before going on air.
To build some low pass filters I found this practical document.
https://www.qrp-labs.com/images/lpfkit/gqrplpf.pdf
Guido - IW5ALZ
Bruce Land
michal777
j
Timothy Cose
