Open Sourced Hydraulic Controller
A hydraulic controller that lets you flip-flop the direction of the rocker switch with a rock switch
Public Chat
This project allows you to swap direction of the rear hydraulic remotes (2 spool) without having to get out of your tractor! There is no software involved with this project. Only some 3D printing for the shroud and a simple printed circuit board that allows you to change the direction of the rocker switch with a slider switch.
Check out this video that goes over why I have open sourced this project. It also is the best place to start from if you want to build this controller for yourself!
  • 1
    General build guidelines
    Go to the github link for the instructions, which are in .pdf format. These files will show you how to assemble the PCB and shroud. The wiring diagram for the cables is also provided.
    1. Grab files form github and Thingiverse
    2. Purchase PCB from PCBWay and components from Digikey
    3. 3D print shroud files
    4. Assemble PCB, watch this video for some tips on assembly:
    5. Follow the instructions from github on how to assemble the final product
    6. Use the wire diagram from github for a guideline on how to create the wire harness
View all instructions
