The see through LED display panel is rigid PCB, which means is not cheap with all the drill holes but it makes a cool display ($40 AliExpress). The alternative would be one 32x16 flex panel using 5050 smd LEDs or two 16x16 (cheap $2 per panel) .. Font characters use 7x5 pixels
