16-bit mode
A project log for YGMII
YG's Media Independent Interface, in case your miniMAC is on a different chip than your miniPHY
yann-guidon-ygdesYann Guidon / YGDES • 04/02/2026 at 19:15•0 Comments
A number of other applications work with 16-bit words, they don't seem to need control and/or parity.
From there it becomes easy to use the saved 2 bits as TMPI/inversion bits, using one bit for the inversion and 4 bits of data/payload.
Going 32-bit is as easy as : one 16-bit word (4 cycles) with one clock direction, and another word is the opposite clock direction. An "aborted" cycle would do the framing.
At that point, I wonder if/how the clock signals could become part of the inverted word, and how to recover the combined transition/word (3 down to 2 signals), if it's even possible... => the answer is "it does not matter":
If the clock signals are TMPIed, then that's 6+1 bits => 4 changes.
Result/change is the same, but one is simpler and more straight-forward, following the existing clocking scheme.
