J138 SPDC version 1 issue 2 initial sketch.pdf
Initial sketch, showing the STEbus interface and PAL.
Adobe Portable Document Format - 107.87 kB - 04/15/2026 at 22:17
Preview
J138_U4_edited.eqn.txt
First draft edits
plain - 3.56 kB - 04/13/2026 at 23:52
Download
J138_U4.eqn.txt
Equations for IC4
plain - 1.52 kB - 04/13/2026 at 23:52
Download
J138_U4.jed
Fuse map for IC4 (MMI PAL 16R4ACN)
jed - 2.76 kB - 04/13/2026 at 20:37
Download
765_FDC_datasheet_1988-12.pdf
Adobe Portable Document Format - 332.90 kB - 04/05/2026 at 02:34
Preview
Faraday_FE2100.pdf
Datasheet showing how it sits between the FDC and the PCbus interface. Most connections are between these two chips.
Adobe Portable Document Format - 214.16 kB - 03/29/2026 at 22:30
Preview
