Connectors
04/05/2026 at 02:51 • 0 commentsPL1 STEbus connector
PL2. Disk DMA control connector
PL3 Standard 34-way floppy disk connector
Parts list
04/05/2026 at 02:37 • 0 commentsSemiconductors
IC1 LS245 STEbus data buffers IC2,3,5 LS244 STEbus address buffers IC4 PAL6R4 J138_U4 IC6 uPD765 FDC IC7 74LS30 IC8,11 7405 IC9 FE2100 LSI glue logic IC10 74LS04 IC12 74LS07 TR1,2 2N2369A NPN
Resistors
R1 4k7 R2,3,5,6 150R R4 200k R7,8 2k2
Capacitors
C1,2,7,12 22µ 16V tantalum C3-7,8-12,14,16 100n C13 47p
Miscellaneous
XL1 8 MHz crystal
Catalogue page
03/29/2026 at 22:40 • 0 commentsSPDC PC-Compatible Floppy Disk Controller
The SPDC is a floppy disk controller for STEbus PC-compatible systems. Controlling up to four drives, the SPDC can be used with 5.25" or 3.5" drives (40 or 80 track double-sided double density). An on-board custom IC interfaces with the industry standard Intel 8272 or NEC µ765 floppy disk controller chip, to provide complete PC-compatibility, when used with other STEbus PC boards. With no links on-board for set up, the SPDC is simple to install and use.
Interface:
STEbus slave interface.
Power consumption:
Typ 0.5A @ 5V
Features:
- Supports DMA and interrupts
- Up to four 3.5" or .25" floppy drives
Ordering information:
SPDC Floppy Disk Controller
Keith
