Parts printed... check. (2 kgs of PLA later)
Annoying sourcing of electronics (because I'm poor)... check.
Impatient wait for delivery of electronics... check. (good thing I made one of those spinner-thingies)
Local sourcing of nuts and bolts... check.
The hardest part of this build was deciding what I wanted for dimensions. I went for a 36" x 29" x 3" build area. This is large.
*EDIT* The hardest part of this build was figuring out the wiring for a series connection between two opposite-direction steppers. The instructions were strong, but my mind was old and weak. More on this later.
ken.do
This pictures was taken when I had almost all the parts printed. Sorry no banana for scale, but some of these parts were 130mm in Z.
Douglas Miller
Chris
cprossu
bfoz
Ken,
I have built/rebuilt a dozen or more MPCNCs and various machines inspired by it. I am the developer of the brushless-motor needle cutter for RC foamboard that has been mentioned/discussed numerous times on the V1Engineering (formerly Vicious1) site and in lengthy threads on the Flitetest forum and others. The MPCNC has gained a real following in the RC community... I used it almost exclusively during needle cutter development and that included an actual weekend MPCNC pictorial build of a new one when the one I was using had to suddenly go home to its owner.
You mentioned several difficulties you've had with this project -- though you seem to be doing pretty well actually -- so I can't stress enough how helpful/patient Ryan and others on the V1Engineering forum can be in walking you through the build. If you've tapped in to that forum already... great! If not, you are really missing out on the best resource for help with building your MPCNC.
Also, I sourced all my own parts for my first MPCNC build and by the time I added up all the hassle, shipping, etc... Ryan's hardware bundle -- nuts/bolts, electronics, everything -- is a real bargain; i.e. I paid more, in the long run, sourcing all my own parts. I've purchased several bundles since and never looked back.
I'm a 72 year-old, retired, electrical engineer and this is simply my thoughts regarding an extremely affordable and flexible machine. Totally voluntary, I get nothing from it... I'm just a very satisfied custromer, who recognizes a pretty nice feat of engineering when he sees it. I'd love to hear how your build is coming along. If I can help, please let me know.
-- David (aka "dkj4linux") Johnson
