Revised the setup menu,
Used a hierarchy structure so as i can add more options in future.
Tested on oled. test is small , maybe i will change the fonts to a suitable size ..
A project log for WiFi 3 channel Temperature Switch
The temperature switch takes three readings from three sensors and displays then on oled and also according to the conditions switch relay
