1How to make MirrorBallBot
This robot has been designed to be open-source, that makes the thinking process a bit more outside-in. This also means I wrote extensive documentation, covering several aspects of the robot.
Because the complete manual (MirrorBallBot_ReferenceManual) is almost 170 pages, it could intimidate at first glance, so I derived a shorther version (MirrorBallBot_QuickStartGuide) that only focuses on making the robot. The Reference Manual remains available.
The Quick Start Guide is suggested for most makers: It's concise, action-oriented, and will get you from zero to a working robot with minimal friction.
The Reference Manual is suggested when you want to understand *why* something works, encounter an issue not covered in the Quick Start Guide, or are curious about the design process, custom I2C protocol, PID controller theory, etc.Recommendation: Start with the Quick Start Guide. Follow the steps, and refer to the Reference Manual only when you need more detail.
Just for reference, the ReferenceManual is organized in almost 40 chapters and divided in into 4 main sections:
- Section 1: Introduction.
- Section 2: Make the robot.
- Section 3: Use the robot.
- Section 4: Useful (or interesting) info.
- Introduction:
- Overview
- Key innovations
- Robot architecture
- Blocks diagram
- Safety and expectations management
- Make the robot:
- BOM
- Wooden or 3D printed base version
- Make the MirrorBallBot PCB
- Make the wood base
- Setup the Raspberry Pi 4B+ and the RP2040-Zero
- First tests
- Assemble the robot
- Use the robot:
- GUI
- Calibrations
- Info (my preferred part 😊, yet not strictly needed to build the robot):
- Inspiration
- Design process
- Main innovations and main characteristics
- Custom I2C protocol
- PID balance Controller
- Configuartion parameters
- Troubleshooting
- Q&A.
The documents can be downloaded from this GitHub folder:
Andrea Favero
2026/09/12
