Because the complete manual (MirrorBallBot_ReferenceManual) is almost 170 pages, it could intimidate at first glance, so I derived a shorther version (MirrorBallBot_QuickStartGuide) that only focuses on making the robot. The Reference Manual remains available.
The Quick Start Guide is suggested for most makers: It's concise, action-oriented, and will get you from zero to a working robot with minimal friction.
The Reference Manual is suggested when you want to understand *why* something works, encounter an issue not covered in the Quick Start Guide, or are curious about the design process, custom I2C protocol, PID controller theory, etc.
Recommendation: Start with the Quick Start Guide. Follow the steps, and refer to the Reference Manual only when you need more detail.
