1What to do if you want to build your own
- Fork the github repository: github repo walkie talkie
- Review the circuit diagram and photos.
- Add or modify CAD files in the repository
- Wire one black-style or grey-style unit, or create a new board profile.
- Set the correct peer MAC addresses in menuconfig
- Build and flash the firmware.
- Test audio at short range first.
- Tune mic gain, speaker gain, channel, and antenna placement.
- Test range outdoors with clear line of sight.
If your wiring differs, add a new board profile instead of hardcoding changes over the existing black/grey profiles. That keeps the firmware easier for other builders to understand.
Aditya Verma
