Build Log #1 — The Five Impossibilities, or: How a Failed Audit Founded a CPU
07/13/2026 at 13:55 • 0 comments(draft for hackaday.io/project/206144 · derived from PROJECT_ABSTRACT_canonical.md · 2026-07-13)
The most productive design review in this project's short history is one we got wrong.
PTSG-CPU-Formation is the third repository of the PTSG ecosystem, and its first Formation: a minimal instruction-driven datapath — accumulator, Horner-step MAC, an explicit data stack, packet-parameter memory with atomic boundary commit — built around the frozen PTSG-Core, entirely inside the Core's window discipline. One line: a deterministic data machine built on a clock that cannot be argued with.
It was born sideways, the way everything in this ecosystem is born. While drafting the packet-parameter engine for the FPGA Spectrum Engine's WPMS synthesizer, the instruction set kept growing more general than its application. So we ran a review with an inverted question. Not what should we add? but: what can this machine never be — not inefficiency, impossibility?
The audit came back with five impossibilities, each one the shadow of a doctrine we actually wanted:
- It cannot branch on its own data. No flags register, no compare. The core is data-blind by creed.
- It cannot capture a return address. No subroutines, no recursion — because the timing chart must stay readable as the program text.
- It cannot read its own writes within a window. Staging lands on a shadow page; the page you're playing from cannot be touched.
- It cannot own its program. No load path, no self-modification. The tines of the music box are planted from outside; the planting is the performance.
- It cannot be interrupted. Preemption is jitter incarnate.
Tidy. Convincing. And then we read the Core repository properly — and two of the five collapsed. The Core already captures return contexts (a holding register auto-saves state on branch, call, and insertion; an external stack bus delegates nesting depth outward), and it already has interrupts: Insertion exists, honored at packet boundaries — not absent, but quantized to the deterministic grid. A third impossibility turned out to have a front door (ALU flags exported as external Condition lanes, so the core stays data-blind while the loop closes outside), and a fourth turned out to be doctrine — a per-profile choice, not law.
Only one impossibility was actually law: the program's owner stands outside the machine.
That correction was the founding insight. A machine this close to CPU-hood, held back only by chooseable doctrine, deserved its own repository — a master data ISA from which applications are made by subtraction. The WPMS engine becomes the first subtraction profile, and the parent project stays what it has always been: the mother that keeps birthing generic children and becomes each child's first customer.
What exists as of tonight, in the same launch shape PTSG-Core itself once had:
- The repository, four Open Prompt layers, CC0/CC0/MIT/CC0.
- Five Layer-1 chapters: philosophy (including the corrected audit — the impossibilities we keep are the product), the register file and the read-only quartet SN/SSS/K/I (now, here, when, which — time itself as an operand), the Command × Phase behavior table (eighteen instructions; no instruction exists until its row is ratified), the memory architecture (BG computes, Q commits: the page swap lands jitter-free on the packet boundary, so glitch-freedom is structure, not discipline), and the Core interface contract (nine lanes; "the Core never waits").
- The deliberation worksheet and the founding dialogue itself, published as the first Layer-2 reasoning trace — this ecosystem publishes its design conversations, architect and AI amanuensis both, as reproducible public record.
You will find no resource figures in this log, and none anywhere in the repository outside Layer 4. That is a governance rule, not an oversight: Measured, not promised. Numbers will exist only as measurements pinned to a named revision, device, and toolchain — the first of which will arrive with silicon evidence on a Terasic C5G, a pure-fabric board whose lack of a hard processor is the methodological control.
Next: the first instruction-list demo (a Maclaurin exponential as a MAC sequence — the machine computing e the way it will one day compute everything else), and the hand-off that closes the loop: PTSG-WPMS-Formation, produced from this master by subtraction, going home to the synthesizer that started it all.
--------------------------------------------------------------------------------------ビルドログ #1 — 五つの不可能、あるいは: 失敗した監査はいかにしてCPUを設立したか
(日本語版)
このプロジェクトの短い歴史で最も生産的だった設計レビューは、間違っていたレビューです。
PTSG-CPU-FormationはPTSGエコシステム第三のリポジトリにして、最初のFormationです: アキュムレータ、HornerステップMAC、明示データスタック、原子的境界コミット付きパケットパラメータメモリからなる最小の命令駆動データパスを、凍結されたPTSG-Coreの周囲に、Coreのウィンドウ規律の完全な内側に築いたもの。一行で言えば——議論の余地なきクロックの上に建てられた、決定論的データマシン。
これは横ざまに生まれました——このエコシステムの全てがそう生まれるように。FPGA Spectrum EngineのWPMSシンセサイザーのためのパケットパラメータエンジンを起草するうち、命令セットは応用よりも汎用に育ち続けた。そこで私たちは、問いを反転したレビューを行いました。何を足すべきかではなく: この機械が決してなり得ないもの——非効率ではなく不可能——は何か?
監査は五つの不可能を返しました。どれも、私たちが実際に望んでいた教義の影でした:
- 自らのデータで分岐できない。 フラグレジスタも比較命令もない。コアは信条によりデータ盲目である。
- 戻り番地を捕獲できない。 サブルーチンも再帰もない——タイミングチャートがプログラムテキストとして読める性質を守るために。
- ウィンドウ内で自らの書き込みを読み返せない。 ステージングはshadowページに着地する;演奏中のページには触れ得ない。
- 自らのプログラムを所有できない。 ロード経路も自己改変もない。オルゴールの櫛歯は外から植えられ、植えること自体が演奏である。
- 割り込まれ得ない。 横取りはジッターの化身である。
整然として、説得力があった。そして私たちはCoreリポジトリをきちんと読み——五つのうち二つが崩れました。Coreは既に戻りコンテキストを捕獲しており(保持レジスタが分岐・コール・Insertionで状態を自動退避し、外部スタックバスがネスト深度を外へ委譲する)、既に割り込みを持っていた: Insertionは存在し、パケット境界で受理される——不在ではなく、決定論的グリッドに量子化されていたのです。第三の不可能には正門があり(ALUフラグを外部Conditionレーンとして公開すれば、コアはデータ盲目のままループは外で閉じる)、第四は法ではなく教義——プロファイルごとの選択——でした。
実際に法だったのはただ一つ: プログラムの所有者は機械の外に立つ。
この訂正こそが設立の洞察でした。選択可能な教義だけでCPUに届くほど近い機械は、自らのリポジトリに値する——応用が引き算で作られるマスターデータISAとして。WPMSエンジンは最初の引き算プロファイルとなり、親プロジェクトはこれまで通りの存在であり続けます: 汎用の子を産み続け、その一人一人の最初の顧客になる母体として。
今夜の時点で存在するもの——PTSG-Core自身がかつてローンチした姿そのままに:
- リポジトリ、Open Prompt四層、CC0/CC0/MIT/CC0。
- 第1層の五章: 哲学(訂正済み監査を含む——保持する不可能こそが製品である)、レジスタファイルと読出し専用カルテットSN/SSS/K/I(今・ここ・いつ・どれ——時間そのものがオペランド)、Command × Phase挙動表(18命令;行が裁定されるまで命令は存在しない)、メモリアーキテクチャ(BGが計算しQがコミットする: ページスワップはパケット境界にジッターフリーで着地し、ゆえにグリッチフリーは規律ではなく構造である)、そしてCoreインターフェース契約(9レーン;「Coreは決して待たない」)。
- 協議作業物と、設立対話そのもの——最初のLayer 2推論軌跡として公開。このエコシステムは設計の対話を、アーキテクトとAI祐筆の両方を、再現可能な公開記録として刊行します。
このログにも、リポジトリのLayer 4の外のどこにも、リソース数値は見つからないはずです。それは見落としではなく統治規則です: 約束せず、測って刻む。 数字は、命名された改訂・デバイス・ツールチェーンに釘付けされた実測としてのみ存在します——その最初のものは、Terasic C5G——ハードプロセッサの不在こそが方法論的対照である純ファブリックボード——上のシリコンエビデンスと共に到来します。
次回: 最初の命令リストデモ(マクローリン指数関数のMAC列——この機械がいつか他の全てを計算するのと同じやり方でeを計算する)、そしてループを閉じる引き渡し: このマスターから引き算で作られたPTSG-WPMS-Formationが、全ての始まりだったシンセサイザーへ帰郷します。
Tsuneo.Ohnaka
