1Assemble the PCB
Solder the MCP23017, terminal blocks, and header pins. We used a hot air station at 300°C for the SOIC package — took about 20 minutes.
2Wire the solenoids
Each solenoid gets +12V from the PSU and ground through a MOSFET (IRLZ44N) controlled by the MCP23017. Add a flyback diode (1N4007) across each coil.
3Mount the reed switches
Hot glue them to the locker door frame. The magnet goes on the door itself. Wire the switch to the screw terminal — one side to 3.3V, the other to the expander input.
4Flash the Pi
Write Raspberry Pi OS Lite to a 32GB SD card. Enable I2C and serial in `raspi-config`.
5Install the software
Clone our repo, run `make` to compile the locker controller, and `systemctl enable locker.service`. The service auto-starts on boot.
6Configure Nayax.
Pair the VPOS via Bluetooth to the Pi. Set the terminal to "unattended mode" — it'll auto-approve transactions under $50.
7Test
Run `python3 test_locker.py` to cycle all doors open/close. Then run a test payment with a $0.50 charge to your own card.
Himanshu Dada
