After several amplifier projects, I wanted to build a compact Hi-Fi stereo amplifier based on the well-known STK4191II power amplifier IC. My goal was not only to build a reliable amplifier but also to design a complete PCB board with an integrated tone control stage, power supply, and speaker protection relay.
The result is a clean and easy-to-build amplifier that delivers excellent sound quality while remaining simple enough for hobbyists to assemble.
All of the PCB boards shown in this project were manufactured by JLCPCB.
2
Main Features
Compatible with the STK41xx series
Independent Volume, Bass, and Treble controls
Power-on delay relay for speaker protection
On-board 7812 voltage regulator
Compact single PCB board design
Easy to assemble and troubleshoot
3
PCB Board Design
The entire amplifier was designed on a single PCB board to simplify wiring and improve reliability.
The board includes:
AC to DC rectifier
Power supply filter
Tone control circuit
Relay delay circuit
STK41xx amplifier section
After completing the design, I uploaded the Gerber files to JLCPCB.
The manufactured PCB boards arrived about one week later with excellent quality. The silkscreen is sharp, the solder mask is clean, and the drilled holes are accurately aligned, making assembly straightforward.
