I am working on an ESP32-based smart environmental monitoring system designed to continuously collect information from multiple sensors and provide a reliable way to monitor changing conditions in real time. The main goal of the project is to build a compact and affordable device that can measure temperature, humidity, air quality, light intensity, and other environmental parameters while displaying the collected information in an easy-to-understand format. I want the system to be useful for both experimentation and practical applications, so the hardware is being designed around commonly available components and the software should remain flexible enough to support additional sensors in the future. The ESP32 is being used as the central controller because it provides sufficient processing capability along with built-in Wi-Fi and Bluetooth connectivity, which makes it possible to collect sensor readings locally while also transmitting selected information to another device or web interface.
One of the main technical challenges I am trying to solve is maintaining consistent sensor readings when several sensors are operating at the same time. Each sensor can have different communication requirements, update intervals, and initialization procedures, so I am designing the firmware to handle the sensors independently rather than relying on one large blocking loop. The project will use a combination of I2C, analog, and digital interfaces depending on the sensor being connected, with appropriate error handling for situations where a sensor becomes disconnected or stops responding. I also want the firmware to detect unrealistic readings and communication failures instead of blindly displaying incorrect values. This should make the monitoring system more reliable during long periods of operation and will also make troubleshooting easier when experimenting with different sensor modules.
Another important part of the project is the wireless communication layer. The ESP32 will periodically process the sensor readings and make the latest information available over Wi-Fi, allowing the data to be viewed without physically connecting the board to a computer. I am considering a lightweight local web interface where the current measurements can be displayed along with historical values collected during the monitoring session. The communication system needs to be designed carefully because I do not want network problems to interfere with the core sensor-reading process. If the Wi-Fi connection drops, the device should continue collecting data locally and automatically attempt to reconnect rather than freezing or restarting the entire monitoring application. I am particularly interested in finding a clean architecture for separating sensor acquisition, data processing, wireless communication, and user-interface functions on a resource-constrained microcontroller.
Power management is another area I want to investigate as part of the project. Although the prototype can initially operate from a USB power source, I would eventually like to make the system suitable for battery-powered operation. This requires understanding how much power each sensor consumes, how frequently measurements need to be taken, and whether the ESP32 can enter low-power modes between measurement cycles without causing reliability problems. The hardware will therefore be designed with power consumption and voltage requirements in mind, including appropriate regulation and protection where necessary. I also want to investigate whether certain sensors can be powered only when a measurement is required, which could potentially reduce the overall energy consumption. These experiments should help determine whether the final design can operate for an extended period without requiring frequent battery replacement or recharging.
For the software side, I am planning to structure the firmware so that individual components can be tested independently before everything is combined into...
ACROBOTIC Industries
Danie Conradie
Vishnu Mohanan
Alex
