Below is a shot of the original Power Supply board in question.
It brings AC voltages into the machine, rectifies and regulates it to deliver +5v, +12v and -5v to the motherboard. A lot going on here, and no point in trying to replicate it. As long as the replacement delivers the right voltages, with enough current capacity.
I have lots of 19vdc laptop power bricks around, with standard barrel jacks. So, that's where I was going for a primary source of power.
Below is a shot of the pcb designed by my predecessors:
(Apologies for the quality). I didn't use their exact circuit, but the board layout was dimensionally compatible with original in terms of size, mounting holes, and pcb footprints for the switch and output header that I would eventually steal from the old board. It was therefore useful for designing my own PCB.
KJoh
