MD Performance Boost Controller
Smart standalone electronic boost controller with display, MAP sensor and advanced PWM control
The MD Performance Boost Controller is a standalone electronic boost control system designed for turbocharged engines.
The main goal of the project is to create a flexible controller that can manage a boost control solenoid using not only PWM duty cycle, but also configurable PWM frequency and different control strategies based on engine operating conditions.
The device is being designed as an independent module and does not require a specific aftermarket ECU.
Main Features
  • Integrated MAP / boost pressure sensor
  • RPM input
  • Vehicle speed input
  • Gear detection / gear input
  • Boost control solenoid PWM output
  • Adjustable PWM duty cycle
  • Adjustable PWM frequency
  • Boost targets depending on RPM and gear
  • Minimum and maximum boost control parameters
  • Delta-based boost correction
  • Correction by duty cycle
  • Correction by PWM frequency
  • Combined duty-cycle and frequency correction
  • Real-time boost pressure monitoring
  • Graphical display
  • Configuration and diagnostic menu
Solenoid Diagnostics
One of the goals of the project is to make the output stage more intelligent than a simple MOSFET driver.
The controller is planned to monitor the boost solenoid circuit and detect conditions such as:
  • Short circuit
  • Overcurrent
  • Disconnected solenoid / open circuit
  • Output driver fault
This will allow the controller to disable the output and report a fault instead of continuing to drive a damaged circuit.
Control Concept
Traditional electronic boost controllers mainly modify the PWM duty cycle applied to the boost control solenoid.
This project will experimentally explore a wider control model where three parameters can be used:
Duty Cycle
Controls how long the solenoid remains energized during each PWM period.
PWM Frequency
Controls how often the solenoid is switched.
Combined Control
The controller can modify both duty cycle and frequency depending on boost error and engine operating conditions.
The purpose is to investigate whether different solenoids and pneumatic systems can respond better to different PWM strategies.
Example Control Inputs
The boost target can potentially depend on:
RPM → Gear → Vehicle Speed → MAP Pressure → Target Boost → PWM Control
For example:
  • Lower boost in 1st gear
  • Increased boost in higher gears
  • Different boost targets across the RPM range
  • Progressive boost increase instead of an immediate pressure spike
Hardware Concept
The planned hardware includes:
  • Microcontroller
  • Internal MAP sensor
  • Protected automotive power supply
  • High-current protected MOSFET output stage
  • Current / output feedback
  • RPM input conditioning
  • CAN interface for future integration
  • Display
  • Buttons or rotary control for configuration
Future versions may also communicate directly with an ECU over CAN and obtain RPM, throttle position, vehicle speed and other parameters digitally.
Project Goals
The project is intended to become part of the MD Performance automotive electronics ecosystem.
The development stages include:
  1. PWM solenoid driver development
  2. Short-circuit and open-load diagnostics
  3. MAP pressure measurement
  4. RPM and speed inputs
  5. Closed-loop boost control
  6. Gear-based boost maps
  7. Display and user interface
  8. CAN integration
  9. Vehicle testing and calibration
The project is currently under development.
I will publish hardware concepts, control algorithms, test results and prototype progress as the project evolves.
Feedback from people working with turbo systems, boost solenoids, motorsport electronics and embedded automotive systems is very welcome.
