Demo using Asterisk PBX and web API:
(My son demonstrating ESPager using our payphone we restored)
Demo using the web interface:
(No PBX needed)
What sets this project apart from others:
* Reuses the real pagers original hardware
* Works with POCSAG or GSC (Golay Sequential Code) pagers
** (The first project I have seen that is actually compatible with the GSC Pagers)
* Minimal parts list/modifications
* Easy to use web interface
* Integrates easily with asterisk PBX software
* STL files to 3D print your own programming adapter for Motorola Advisor
* Hack the Planet retro inspired theme makes it feel period correct
* XIAO ESP32 C3 has a built in battery charging circuit and you can trim the bottom of the pager to expose the USB C port.
Corey Harding
Loïc Daigle
Himanshu Dada
