To make the sword interactive without ruining its aesthetic, the entire circuit had to be compact enough to hide completely inside the pommel.
The brain of this project is the Waveshare RP2040-Tiny development board, which is paired with the DFPlayer Mini module. This reads the MP3 files from a MicroSD card and features a built-in amplifier to drive a small speaker hidden in the sword. For motion sensing, we have used the MPU6050 accelerometer and gyroscope. This tracks the physical orientation and G-forces acting on the sword in real time.
This article covers the complete build process of this project, so let's get started with the build.
NARSIL
If you are familiar with LOTR, you know Narsil is one of the most famous weapons in fantasy history. Originally the sword of King Elendil, it was a symbol of the kingdom of Gondor.
During the War of the Last Alliance, Elendil fell in combat against Sauron, and Narsil shattered beneath him. His son, Isildur, took up the broken hilt and used the remaining jagged shard of the blade to slice the One Ring directly off Sauron’s hand, defeating the Dark Lord and ending the war. For thousands of years, the shards were kept as a treasured heirloom in Rivendell, symbolizing the broken line of kings, until they were eventually reforged into Andúril for Aragorn.
3D MODEL
To create the 3D model of Narsil, I first searched for a front-view image of the sword and imported it into Fusion 360 using the Canvas feature. I then traced the image to recreate the overall shape of the sword, including the blade, fuller, crossguard, hilt, and pommel, while keeping the design as close to the original as possible.
I divided the model into three main sections to make the design and assembly easier. For the finer details, I referred to additional reference images and recreated the design elements directly in Fusion 360.
Since this isn't just a display piece but an interactive prop with electronics inside, I had to adjust the dimensions. The sword is slightly thicker than a regular sword to accommodate the internal electronics, with most of the circuitry housed inside the pommel.
The battery was another challenge. I wanted to keep the electronics hidden without compromising the sword's appearance, so I decided to house the battery inside the fuller of the blade. I'm using a 14500 lithium-ion cell, which has a diameter of approximately 14 mm. Since the fuller section is roughly 16 mm thick, there was just enough space to fit the cell inside.
The main challenge was balancing the internal space required for the electronics with the original aesthetics of Narsil. I wanted the finished sword to look as close to the original design as possible, while still having enough room to bring it to life with the electronics.
FULLER ASSEMBLY
The fuller section of the sword is divided into two parts: the top and bottom sections, which are joined together using two dowel pins for alignment.
The top section houses the 14500 lithium-ion battery, keeping it completely hidden inside the blade. To accommodate the battery, I designed a cutout that can be accessed from the top. I also created a separate lid that fits over the opening to secure the battery in place. The battery wires pass through the fuller sections and connect to the electronics housed inside the hilt.
This arrangement keeps the battery neatly concealed while maintaining the sword's overall appearance without any visible battery compartment.
HANDLE ASSEMBLY
The handle section is divided into two halves, with the main circuit housed between them. I designed openings on one side to provide access to the USB Type-C charging port and the push-button switch, which is used to turn the circuit on and off.
For added structural integrity, I also incorporated a hollow metal pipe between the two halves. This pipe reinforces the handle, making the sword more rigid, while also serving as a passage...
Arnov Sharma
Will Donaldson
