I installed Bazzite OS on the board, turning it into something similar to a compact Steam Machine. However, the main goal was to get Minecraft running on it, and after installing the game, it worked surprisingly well!
For the enclosure, I designed a custom box-shaped housing around the ZimaBoard 2, with dedicated cutouts on one side to access all the I/O ports. To give it that iconic Minecraft grass block appearance, I covered the enclosure with printed grass block textures.
Instead of painting the design or trying to 3D print the textures, I created scaled paper templates for all four sides, along with the top surface. These were color-printed on thick paper, cut to size, and attached to the enclosure. Finally, I applied a clear protective coating to make the finish more durable.
In this article, we'll go through the complete build process of this Minecraft Grass Block PC, from setting up the hardware to designing and assembling the enclosure.
So let's get started with the project.
HARDWARE- ZimaBoard 2
For the brain of our project, we selected the ZimaBoard 2, which Zima describes as a single-board server. It is primarily designed for NAS setups, home servers, and self-hosted applications.
The board comes preloaded with ZimaOS, but since I had plans to turn this little machine into a gaming PC, I decided to replace it with Bazzite, a Linux-based operating system designed specifically with gaming in mind.
One of the coolest features of the ZimaBoard 2 is the PCIe 3.0 expansion slot on the side, which allows you to connect additional hardware, including compatible graphics cards and other PCIe devices. This opens up some interesting possibilities for a compact gaming build like mine.
The board features an aluminum body that acts as a passive heatsink, allowing it to operate without a cooling fan under its intended operating conditions. However, since my plan is to push this little machine beyond its recommended thermal and power limits, I decided to add an active cooling fan to keep temperatures under control.
Here's a quick look at its main specifications:
- Storage: 2 × SATA 3.0 ports (6 Gb/s) with power connectors
- Networking: 2 × 2.5 Gigabit Ethernet ports
- Display Output: Mini DisplayPort 1.4, supporting up to 4K at 60 Hz
- Power Input: 12V, 5A power supply
- Expansion: PCIe 3.0 slot for connecting additional hardware
- Cooling: Fanless aluminum enclosure, with an additional fan added for my build
The ZimaBoard 2 used in this project was provided by Zima as a review unit. However, Zima had no involvement in the content of this article and no influence over my opinions, performance evaluation, or any expenses incurred during the project.
Special thanks to the Zima team for providing the hardware!
OS-BAZZITE
For the operating system, I decided to go with Bazzite. My original plan was to install SteamOS, but getting it to work properly with my hardware proved to be quite a challenge.
So, I went with the next best thing: Bazzite, a Linux-based operating system designed to deliver a console-like gaming experience on PC hardware.
BAZZITE INSTALLATION PROCESS
The installation process is pretty straightforward. First, we enter the BIOS, head to the boot menu, and select our bootable USB drive to start the installation.
After a few moments, the Bazzite installer appears, where we select our preferred language. Next, we navigate to System → Installation Destination and select the NVMe SSD as our primary storage drive.
Once everything is configured, we start the installation and let it do its thing. The entire process takes around 15–20 minutes, depending on the hardware and installation setup.
Once the installation is complete, we reboot the system and boot straight into Bazzite, ready to turn our little ZimaBoard 2 into a proper gaming machine.
I've also put together a separate setup guide covering how to install and run Bazzite on similar SBCs. If you're interested in turning your own single-board computer into...
Arnov Sharma
Roger
Danny
Dewet
