13D PRINTED PARTS
For the 3D printing process, we only need to export the models of the base and main body. I exported both parts as mesh files and imported them into Anycubic Slicer for preparation.
I sliced the models with 25% infill and a 0.16 mm layer height. Supports were only required for the I/O section of the base, while the main body and the remaining parts could be printed without any supports.
For the I/O section, I used tree supports with a Z-distance of 0.25 mm and five Z-interface layers.
As for the filament, I didn't use anything special. I simply went with what I had plenty of in stock, which was Creality Hyper PLA.
Once printing was complete, both parts came out nicely and fitted together snugly. With that, our 3D printing process was complete, and we were ready to move on to the assembly!
2BASE PAINT PROCESS
Since we're building a Minecraft Grass Block PC, we want all the visible parts to match the same color profile. The main body will be covered with printed grass block templates, so the base is the only component that won't be fully covered.
The I/O side and bottom of the base will remain exposed, so we decided to give these areas a brown finish to match the dirt section of a Minecraft grass block.
For this, I used a brown aerosol spray paint and applied a few coats to the base. After letting it dry for around two hours, we had a nicely painted component with a brown finish on the bottom and I/O sides.
The remaining areas were left unpainted, which is perfectly fine since they'll be hidden once the enclosure is assembled.
3MINECRAFT GRASS BLOCK TEMPLATES
For the main body, I prepared custom paper templates featuring the iconic Minecraft grass block texture. I used four separate prints showing the grass and dirt pattern for the front, back, left, and right sides, along with a complete grass texture for the top surface.
The main enclosure measures 190 × 190 mm, so I prepared the templates at 187 × 187 mm to ensure they fit nicely within the enclosure's dimensions.
I printed all five templates on thicker A4 paper using a color printer. Once printed, I carefully cut them out to size, and our grass block templates were ready for the next step.
4APPLYING THE GRASS BLOCK TEMPLATES
We begin assembling the paper template with the main body by applying regular paper glue to one side of the enclosure.
To spread it evenly, we use a piece of cardboard, like spreading jam on a slice of bread, except here we're spreading glue over PLA!
Next, we take the Grass Top paper template, carefully position it on the enclosure, and press it into place. We gently rub and press across the entire surface to ensure the paper bonds properly with the 3D-printed part, with the glue evenly distributed in between.
We repeat the same process for the remaining four sides.
For the front side, which has all the I/O port openings, we have one additional step. We first trace the I/O cutouts onto the paper template and use scissors to carefully cut out the required openings. Once that's done, we repeat the gluing process and attach the template to the front side.
5CONFORMAL COAT
Paper isn't exactly the most durable material, especially if you want your project to last for years. It's vulnerable to humidity and moisture and can deteriorate or develop mold over time.
One way to preserve paper surfaces is to seal them with a protective coating such as varnish, conformal coating, or epoxy. Luckily, I already had a conformal coating spray available, so I decided to use that for this project.
I applied two coats of conformal spray over the entire grass block surface, creating a protective layer over the printed paper templates. This should help protect the finish from moisture and everyday wear, making our Minecraft Grass Block PC more durable in the long run!
6BASE ASSEMBLY
We begin the base assembly by removing the two M2 mounting screws from the bottom of the ZimaBoard 2.
Next, we place the ZimaBoard 2 inside the base, aligning it with the designated mounting points. We also position the SATA SSD right beside the board, within its dedicated holding ribs. I've added double-sided tape inside these supports to keep the SSD securely in place.
Once everything is positioned correctly, we flip the base over and reinstall the two M2 screws through the mounting points.
Using the provided Torx screwdriver, we tighten both screws, securing the ZimaBoard 2 firmly to the base.
And with that, our base assembly is complete!
7FINAL ASSEMBLY
For the final assembly, we position the base assembly inside the main enclosure, align the mounting points, and secure both sections together using four M2 screws from the bottom.
And with that, our Minecraft Grass Block PC is finally ready!
8RESULT
And here's the end result of our fun little build: a giant Minecraft Grass Block that's also a fully functional PC!
Powered by the ZimaBoard 2, this has turned out to be a genuinely fascinating project and probably one of my favourite builds so far. Thanks to the relatively simple construction, what we've essentially created is a fancy custom enclosure for the ZimaBoard 2 that looks just like a Minecraft grass block!
Now, let's get everything connected. The ZimaBoard 2 only has two USB ports, so I used the first USB 3.0 port for a USB hub, which allowed me to connect the wireless dongles for my mouse and keyboard. The second USB 3.0 port is occupied by a Wi-Fi and Bluetooth dongle. Yes, the ZimaBoard 2 doesn't have onboard Wi-Fi or Bluetooth, so we need an external adapter for wireless connectivity.
For the display, I connected an HDMI monitor using the included HDMI-to-DisplayPort adapter. Finally, I plugged in the 12V 4A power adapter, and the system booted straight into Bazzite!
And just like that, our Minecraft Grass Block PC was ready to go!
9MINECRAFT
Now comes the best part of this project: actually running Minecraft on our Minecraft Grass Block PC!
For this, we're using Prism Launcher, which we downloaded directly from its official website. I went with the AppImage version, making the installation process on Bazzite pretty straightforward. After configuring the launcher and installing Minecraft, I was ready to jump in.
We managed to get over 150 FPS, which is honestly pretty impressive for a little machine like this!
I spent several hours playing Minecraft on this setup, and the experience was surprisingly similar to playing on a regular desktop PC. Everything felt smooth, and it's genuinely fascinating to see a tiny single-board server handle a game like this so well.
I haven't experimented with shaders yet, but looking at the performance, I reckon the ZimaBoard 2 should be capable of handling some lightweight shader packs, such as Potato Shaders or lower-quality BSL presets. I personally prefer the original Minecraft look without shaders, so I decided to keep things as close to the vanilla experience as possible for this build.
Now, here's another interesting detail: power consumption!
We're running this entire setup with the Intel N150 configured at just 10W, which is pretty bonkers considering the performance we're getting. For context, Intel specifies a base processor power of 6W for the N150, with a maximum turbo frequency of 3.6 GHz.
There's also some room to experiment with the processor's power limits. I haven't tweaked these settings yet, but it's definitely something worth exploring in a future update!
10OVERVIEW
And that brings us to the end of our Minecraft Grass Block PC build!
The system runs Bazzite from the SATA SSD we connected, while the onboard eMMC still has ZimaOS installed. This means we can still switch back to using the board for NAS applications, or alternatively, wipe the existing installation and use that storage for our gaming setup.
All things considered, the ZimaBoard 2, whether you call it a single-board computer or, as the Zima team puts it, a single-board server, is quite a capable little machine. Being able to run Minecraft at such impressive frame rates on a compact, low-power system is genuinely fascinating.
But here's the funny part: this little setup is capable of much more than just running Minecraft! I've actually been experimenting further with the ZimaBoard 2, including pairing it with a dedicated GPU and trying to run some more demanding games, including Cyberpunk 2077.
But that's a story for another project. Stay tuned, because things are about to get interesting!
As always, I've attached all the relevant project files to this article, including the 3D models, CAD files, and other build resources, so you can recreate the project yourself.
Special thanks to Zima Team for supporting this project! Do check them out for their range of single-board computers, NAS solutions, home server hardware, and accessories for your next homelab or DIY project. Visit ZimaBoard and see what you can build!
Thanks for reaching this far, and I will be back with a new project real soon.
Peace.
Arnov Sharma
