1Step 1
Remove the old workings from an old ZX Spectrum. (but never destroy a working one!)
2Step 2
Solder the keyboard connectors to the Arduino Pro Mini via some wires.
3Step 3
Build the USB adapter using the 5 components. A copy of the circuit diagram is in the GitHub repository.
5Step 5
Use an FDTI adapter or Arduino Lilypad programmer to programme the Arduino Pro Mini. The source is on the GitHub repository.
7Step 7
Test it with a PC and put the screws in if it works.
