It will be an on-going development of my first Data HMD.
This working Data HMD can be found here Data Glasses for multimeter
And again, the optics will be the challange. This time I will try to make it work with a more common lens.
I'm not sure if I will create a PCB or just use finished modules. Let's start...
Alain Mauer
Michael Gardi
SAYANTAN PAL
Tyler Bourne
chris0x00
By using the calculator you gave the link to and the google lens (f=4.5cm), is it correct that you had to place the display at ~5.5cm to get the correct focus? I would have infered from your 3D file but I see you haven't put it out yet.
I'd love to built me one of these. My thesis was pretty similar and the biggest pain is the focus(!!!), i.e. I feel your problem ;)
