1Step 1
So that's it? What do I do now?
Well this is just the tip of the iceberg. There are many uses for electrolysis and one important one we believe is the ability to coagulate pollutants to they are easily filtered. If we learn more about the process together we can potentially empower communities to simply and affordably tackle some of their own water issues without resorting to costly methods or outside assistance that may never come.
What can you do with electrocoagulation or electrolysis?
- Learn about hydrogen production
- You can remove rust from metal objects using it as an electrode
- Refine / recoup precious metals
- Use recycled metal materials for electrodes
- Try different types of fluids to coagulate & share your findings
- Learn about electrolysis with students in the classroom
How can I help the Make Water Project?
- Add sensors so we can further study coagulation
- Help build curriculum for the classroom around these kits (coding, chemistry, etc).
- Share your DIY water hacks, stories, and videos for us to share via our youtube channel.
- Help us improve our arduino code and UI so we can easily make adjustments to timing and data entry
One way we introduce students to coagulation is by mixing a couple drops of acrylic paint (found at any crafts store) into the water and it gives a great visual representation of coagulation.
¿Eso es todo? ¿Qué hago ahora?
Bueno, esto es sólo el principio. Hay muchos usos para la electrólisis y uno importante que creemos es la capacidad de coagular los contaminantes para que se filtran fácilmente. Si aprendemos más sobre el proceso juntos, potencialmente podemos potenciar a las comunidades para que aborden de manera sencilla y económica algunos de sus propios problemas de agua sin recurrir a métodos costosos o asistencia externa que quizás nunca llegue.¿Qué se puede hacer con la electrocoagulación o la electrólisis?
- Aprenda acerca de la producción de hidrógeno
- Usted puede quitar el óxido de los objetos de metal que lo utilizan como un electrodo
- Refinar / recuperar metales preciosos
- Utilice materiales de metal reciclado para electrodos
- Pruebe diferentes tipos de líquidos para coagular y compartir sus hallazgos
- Aprender sobre la electrólisis con los estudiantes en la clase
¿Cómo puedo ayudar al proyecto Make Water?
- Añadir sensores para poder estudiar la coagulación
- Ayudar a construir el plan de estudios para la clase en torno a estos kits (codificación, química, etc).
- Comparta sus cortes, historias y videos de agua de DIY para que los compartamos a través de nuestro canal de youtube.
Ayúdenos a mejorar nuestro código arduino e interfaz de usuario para que podamos hacer ajustes fácilmente a la hora y la entrada de datos
Una forma de introducir a los estudiantes a la coagulación es mediante la mezcla de un par de gotas de pintura acrílica (que se encuentra en cualquier tienda de artesanía) en el agua y que da una gran representación visual de la coagulación.
2Step 2
Lets make a coagulator!
Make sure you have all your parts ready.
1x 3D Printed Coagulator Lid - 3D File Link
1x Mason Jar 16oz
2x Electrodes - Type of metal is really up to you but we tend to use one aluminum and one iron.
1x Ludus ProtoShield
1x Arduino Uno
2x M/M Leads
2x Alligator Leads
1x Power Supply
1x USB Cable (whichever size fits your arduino)
Notas en Espanol.
Si alli preguntas del la systema si hablamos espanol y nos puedes mandar mensajes. -
3Step 3
Clip the alligator leads to the male leads coming from the ludus shield.
Clip los alligator leads a los cables que vienen del ludus shield.
4Step 4
Slide the electrodes through the slits/openings of the 3D printed lid. Allow for the alligator clips/leads to hold the electrodes from sliding completely into the jar. (Optional: You can place the electrodes closer or farther apart to see the difference it makes on coagulation time.)
CAUTION: Make sure the electrodes aren't touching in the water. This can short out the system when you power it on.
Deslice los electrodos a través de las aberturas de la tapa impresa en 3D. Deje que los alligator clips /cables para mantener los electrodos de deslizamiento completamente en el frasco. (Opcional: puede colocar los electrodos más cerca o más lejos para ver la diferencia que hace en el tiempo de coagulación.)
PRECAUCIÓN: Asegúrese de que los electrodos no se toquen en el agua. Esto puede cortocircuitar el sistema cuando lo prendas. -
5Step 5
CAUTION Make sure that the positive and negative leads aren't touching each other before taking this step. Plug in the wall power adapter into an outlet and then plug it into the arduino.
PRECAUCIÓN: Asegúrese de que los cables positivo y negativo no se toquen entre sí antes de dar este paso. Conecte el adaptador de corriente de pared a una toma de corriente y luego enchúfelo en el arduino.
6Step 6
If you notice bubbling at the electrodes then you have a working coagulator! If you leave the coagulation process going you will see the tap water begin to coagulate particulates in the water and foam at and around the electrodes.
Si observa burbujas en los electrodos entonces tienes un coagulador que trabaja! Si dejas el proceso de coagulación en marcha, verá que el agua del grifo comienza a coagular partículas en el agua y espuma en y alrededor del electrodos.
7Step 7
Connect Ludus Board to Arduino Uno.
Conecta el Ludus Board a tu Arduino Uno.
8Step 8
Connect Arduino UNO to your computer with the USB cord.
Conecta tu Arduino UNO a la computadora usando el USB cord.
9Step 9
Open the Arduino software of your choice. Create a new sketch and copy and paste the following code
(or download the sketch here).
Habre el programa de Arduino de tu preferencia.
Cree un nuevo boceto y copie y pegue el código siguiente
int pwm_a = 3; // Channel A speed int dir_a0 = 4; // Channel A direction 0 int dir_a1 = 5; // Channel A direction 1 void setup() { // put your setup code here, to run once: Serial.begin(9600); // Pour a bowl of serial pinMode(pwm_a, OUTPUT); // Set control pins to be outputs pinMode(dir_a0, OUTPUT); pinMode(dir_a1, OUTPUT); } void loop() { // put your main code here, to run repeatedly: //drive forward at full speed by pulling DIR_A High //and DIR_B low, while writing a full 255 to PWM to //control speed digitalWrite(dir_a0, HIGH); digitalWrite(dir_a1, LOW); analogWrite(pwm_a, 255); Serial.println(digitalRead(dir_a0)); //wait 5 second delay(5000); digitalWrite(dir_a0, LOW); digitalWrite(dir_a1, HIGH); analogWrite(pwm_a, 255); Serial.println(digitalRead(dir_a0)); //wait 5 second delay(5000); }One of the key features of our coagulator is that we swap the polarity of the electrodes every so often. This is because if we leave one electrode positive and one negative the entire time buildup on the electrode will occur and reduce efficiency and coagulation time. By swapping polarity at intervals this tend to shake off the build up and improve coagulation time/efficiency.
Una de las características clave de nuestro coagulador es que intercambiamos la polaridad de los electrodos cada cierto tiempo. Esto se debe a que si dejamos un electrodo positivo y uno negativo todo el tiempo de acumulación en el electrodo se producirá y reducir la eficiencia y el tiempo de coagulación. Intercambiando la polaridad a intervalos, esto tiende a sacudir la acumulación y mejorar el tiempo y la eficiencia de la coagulación.
10Step 10
Fill mason jar about 3/4 full of tap water. Do not use pre-filtered water or soft water. The harder the water the quicker coagulation can occur. (Optional: You can mix a drop or two of acrylic paint for added visual effect of coagulation. We recommend using clear water first to check and see if the electrodes are creating bubbles.)
Llena el tarro de albanil alrededor de 3/4 de agua del grifo. No utilice agua pre-filtrada o agua blanda. Cuanto más duro sea el agua, puede producirse una coagulación más rápida.
(Opcional: Se puede mezclar una o dos gotas de pintura acrílica para obtener un efecto visual agregado de la coagulación. Recomendamos usar agua clara primero para comprobar si los electrodos están creando burbujas).
Ryan Beltrán
