It costs about 4$, and every other specification is already in the product name.
Now I wanted to use one of these modules to directly drive a high power LED with any 12V battery (I'm using a lead-acid battery).
Modifying this module is not very complicated, anyway I will show you some details of this module, gathered whilst analyzing this part.
Currently, this setup is working, but its not tested well:
* The current can be regulated to: ~0.9-1.4A
* Only one LED setup tested (2x 10W LEDs, 1050mA)
* Only one input voltage tested: 12V/1.5A
* Further testing: input voltage range
* Further testing: output current/voltage range and ripple
* Test different combinations of Shunts
It's very easy to modify this converter to be constant-current controlled:
You need following parts:
1k potentiometer
3W shunt (the value depends, first setup: 0.86Ohm)
2pin Screw terminal
A little bit of 1.5mm² wire
As you can see in the schematic image, not very much to do.
If you need further help, please write :-)
I tested this setup already with following currents and LED power:
Vin: 12V Iout 1050mA, 2x10W LED
Vin: 12V Iout 1750mA, 1x50W LED
You can adjust the current with the poti, if it has the lowest resistor, the current is also the lowest possible one. Due to the FP1539 feedback circuit, the controller regulates until there are 0.5V at the feedback pin.
If you have a 0R poti, this eqals to:
I = U / R = 0.5V / <R-shunt> = 0.5V / 0.68Ohm = 0.735A
Of course, a lower shunt value increases the minimum current, but it also decreases the power losses on the resistor:
Pshunt = I out ² * Rshunt = 1.75A² * 0.68Ohm = 2.1W -> nice, within the specs :-)
If you want to increase the efficiency, decrease the Rshunt value.
For example: If I know, that I only use about 1.5A (or 1.75A+/- a little bit adjustment), let's try different values:
I = U/R = 0.5V / 0.47Ohm = 1.06A min -> Pshunt = 1.75² * 0.47 = 1.43W (only 70% of the previous value)
next value
I = U/R = 0.5V/0.33Ohm = 1.51Amin -> Pshunt = 1.75² * 0.33 = 1.01W (even more efficient)
Ok, for my setup, I will modify my CC controller to support only 1.5A+, but it reduces the wasted heat by 1W (2% :-)).
Next time, I will write about the whole feedback circuit in detail!
I'm a newbie electronics guy. Bought one of the DC/DC Boost converters myself to build a variable power supply. I am going to us an old printer AC/DC power brick that is 32V, 2.5A, which works into this boosters parameters. I hooked it all up, everything works, including varying the voltage. But I'd like to use a larger potentiometer than the little one on the board. I've desoldered the 3296 pot off the board as gently as I could...but not sure how to solder another pot back on. The 3 legs coming off say a 10K pot that I would wire into the booster, which leg goes into which hole in the booster circuit board? I'm definitely not up to tracing down circuits at this point. Any help would be great. thanks Benjamin.
The potentiometer is used as rheostat in this application. The middle output pin is connected to another pin to create a variable resistor. Have a look at this this:
In a rheostat-application the resistor value is much more important then in a potentiometer-application. So measure the resistor value of the old potentiometer (two outmost pins gives the highest value) and just substitute it.
Now how do you connect a substitute potentiometer (rheostat)? The outmost pads on the boost converter are connected by a link. Thats one connection to your substitute potentiometer. To other goes to the pad mostly to the center.
Dear all, sry that I missed your comments, no mail notification enabled :-(.
@dbake5206: If you think of the technology of a typical potentiometer: You have one resistor, and one slider. I don't know one potentiometer, where the resistors beginning/end is not on the outside pins. the slider is always (in my experience) the middle pin. So if you want to solder a new poti: -) slider to the middle pin -) other ends: don't care at all: either maximum voltage is on one side at maximum, or on the other
Can any one please tell me whats the name of those mosfets i also accidently broke them of while removing heatsink!
Thanks in advance
