Code
04/01/2017 at 19:00 • 0 commentsThe code is far from pretty, but it works (at least as long as something goes wrong and it crashes). It gets the current weather information from the OpenWeatherMap API, and displays the icon and temperature, alternating them every 4 seconds. The particular prototype shield I used for testing also has 2 buttons, but they are not used by the code.
import utime from machine import I2C, Pin from ht16k33_matrix import Matrix8x8 import json import urequests API_KEY = "generate your own" CITY = "Zuirich" ICONS = { '00': ( 0b00000000, 0b01000010, 0b00100100, 0b00011000, 0b00011000, 0b00100100, 0b01000010, 0b00000000, ), '01': ( 0b00010000, 0b01010010, 0b00111100, 0b00111111, 0b11111100, 0b00111100, 0b01001010, 0b00001000, ), '02': ( 0b00010000, 0b01010100, 0b00111000, 0b11111110, 0b01000100, 0b10000010, 0b10000001, 0b01111110, ), '03': ( 0b00000000, 0b00000000, 0b00000000, 0b00111000, 0b01000100, 0b10000010, 0b10000001, 0b01111110, ), '04': ( 0b01100000, 0b10011000, 0b10000100, 0b01111000, 0b01000100, 0b10000010, 0b10000001, 0b01111110, ), '09': ( 0b00111100, 0b01111110, 0b11111111, 0b11111111, 0b10001001, 0b00001000, 0b00101000, 0b00111000, ), '10': ( 0b00101010, 0b00011100, 0b01111111, 0b00011100, 0b01111010, 0b11111100, 0b00010000, 0b00110000, ), '11': ( 0b00001111, 0b00011110, 0b00111100, 0b01111111, 0b11111110, 0b00000100, 0b00001000, 0b00010000, ), '13': ( 0b01010010, 0b11010011, 0b00111100, 0b00100111, 0b11100100, 0b00111100, 0b11001011, 0b01001010, ), '50': ( 0b11111111, 0b00000000, 0b11111111, 0b00000000, 0b11111111, 0b00000000, 0b11111111, 0b00000000, ), } DIGITS = { ' ': ( 0b0000, 0b0000, 0b0000, 0b0000, 0b0000, ), '0': ( 0b0111, 0b0101, 0b0101, 0b0101, 0b0111, ), '1': ( 0b0010, 0b0010, 0b0010, 0b0010, 0b0010, ), '2': ( 0b0111, 0b0001, 0b0111, 0b0100, 0b0111, ), '3': ( 0b0111, 0b0001, 0b0111, 0b0001, 0b0111, ), '4': ( 0b0101, 0b0101, 0b0111, 0b0001, 0b0001, ), '5': ( 0b0111, 0b0100, 0b0111, 0b0001, 0b0111, ), '6': ( 0b0111, 0b0100, 0b0111, 0b0101, 0b0111, ), '7': ( 0b0111, 0b0001, 0b0001, 0b0001, 0b0001, ), '8': ( 0b0111, 0b0101, 0b0111, 0b0101, 0b0111, ), '9': ( 0b0111, 0b0101, 0b0111, 0b0001, 0b0001, ), ':': ( 0b0000, 0b0001, 0b0000, 0b0001, 0b0000, ), '.': ( 0b0000, 0b0000, 0b0000, 0b0000, 0b0001, ), '-': ( 0b0000, 0b0000, 0b0001, 0b0000, 0b0000, ), } matrix = Matrix8x8(I2C(-1, Pin(5), Pin(4))) wait = 0 def show(image, dx=0, dy=0): for y, row in enumerate(image): bit = 1 for x in range(8): matrix.pixel(dx + x, dy + y, row & bit) bit <<= 1 matrix.show() def show_text(text): x = 0 for c in reversed(text): if c in '.:-': show(DIGITS.get(c, DIGITS[' ']), x - 1, 1) else: show(DIGITS.get(c, DIGITS[' ']), x, 1) x += 4 def get_weather(): r = urequests.get("http://api.openweathermap.org/data/2.5/weather" "?q=%s&appid=%s" % (CITY, API_KEY)).json() return r["weather"][0]["icon"], int(r["main"]["temp"] - 273.15) while True: if wait <= 0: icon, temp = get_weather() wait = 60 if icon[-1] == 'd': matrix.brightness(9) else: matrix.brightness(2) matrix.fill(0) show_text('%2d' % temp) utime.sleep(4) show(ICONS[icon[:2]]) utime.sleep(4) wait -= 1
deʃhipu
