sketch_wambat_mark2.ino
The "final" version, with all keys' assignments.
ino -
21.07 kB -
04/29/2017 at 03:26
Download
The button reminder for the keyboard top.
Portable Network Graphics (PNG) -
61.27 kB -
04/29/2017 at 03:25
Preview
Final wiring diagram. Note my $3 Arduino had defective pin 5, so I reassigned some lines around.
158.29 kB -
04/29/2017 at 01:57
Preview
07_Label_Cut.nc
Use 1/8 in tungsten single-flute end mill bit for cutting Plexiglass on CNC
Network Common Data Form (NetCDF) -
1.66 kB -
04/25/2017 at 09:54
Download
06_Label_Drill.nc
Use 3 mm drill bit for drilling on CNC
393.00 bytes -
04/25/2017 at 09:54
Download
05_Top_Plate_Cut.nc
Use 1/8 in tungsten single-flute end mill bit for cutting Delrin on CNC
13.04 kB -
04/25/2017 at 09:54
Download
04_Top_Plate_Drill.nc
1.14 kB -
04/25/2017 at 09:54
Download
03_Tray_Cut.nc
834.00 bytes -
04/25/2017 at 09:54
Download
02_Bottom_Plate_Cut.nc
2.43 kB -
04/25/2017 at 09:54
Download
01_Bottom_Plate_Drill.nc
2.22 kB -
04/25/2017 at 09:54
Download
Keys_WAMBAT_Mark_1.pdf
Layout for WAMBAT Mark 1
Adobe Portable Document Format -
35.09 kB -
04/15/2017 at 06:38
Preview
Screen background for WAMBAT Mark 1
71.09 kB -
04/15/2017 at 06:34
Preview
Layout_Mark_5.pdf
Layout for GKOS Mark 5
35.48 kB -
04/15/2017 at 06:20
Preview
sketch_gkos_mark5.ino
This sketch implements the code for modified GKOS input layout; Note this is not a "True" GKOS, as the frequent keys have been reassigned to the index and middle fingers. The code is for Leonardo-compatibles only! v 1.0 3-Apr-17
ino -
20.93 kB -
04/15/2017 at 06:04
Download
sketch_acrus.ino
The initial proof of concept sketch implements the Leonardo code. v 1.0 1-Apr-17
ino -
15.19 kB -
04/03/2017 at 08:00
Download
