The induction heater is built from a redesigned Zero Voltage Switching (ZVS) driver and powered by a small 50V, 2000W DPS-2500AB 2000W P-class proliant blade power supply . While this makes for an exceptionally small induction heater, it’s still very capable.
Standby power loss are 6A@50V(120kHz) with 6 capacitors 0.22uF each. 10 capacitor option allow to reduce oscillation frequency. Device volume size 165x55x55mm
Where can I find the schematics, plz? Effaristopoly.
