A small, 2000W induction heater
To make better/reliable version of existing 1000W zvs induction heater
The induction heater is built from a redesigned Zero Voltage Switching (ZVS) driver and powered by a small 50V, 2000W DPS-2500AB 2000W P-class proliant blade power supply . While this makes for an exceptionally small induction heater, it’s still very capable.
Standby power loss are 6A@50V(120kHz) with 6 capacitors 0.22uF each. 10 capacitor option allow to reduce oscillation frequency. Device volume size 165x55x55mm
Maximum power limit not tested .
2kW induction heater.PcbDoc
Altium
pcbdoc - 2.68 MB - 04/07/2017 at 05:04
Download
2kW induction heater.PcbLib
Altium
pcblib - 789.50 kB - 04/07/2017 at 05:03
Download
PCB_Project_2kW induction heater.PrjPcb
Altium
prjpcb - 43.96 kB - 04/07/2017 at 05:03
Download
2kW induction heater.SchLib
Altium
schlib - 30.50 kB - 04/07/2017 at 05:03
Download
  • 10 × WIMA FKP4 0.22uF 1000Vdc
  • 2 × IRFP4227 Discrete Semiconductors / Power Transistors and MOSFETs
  • 2 × MMBT3904LT1G Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 2 × MMBT3906LT1G Discrete Semiconductors / Transistors, MOSFETs, FETs, IGBTs
  • 2 × MBR2H200SFT1G
View all 14 components
Cozak.da wrote 10/04/2021 at 19:51 point
Where can I find the schematics, plz?  Effaristopoly.
SMOSTAFAD wrote 10/22/2017 at 20:14 point
Hi. Excuse me , I'm Mostafa Danesh.
If possible , I want the schemotic of this project for my essay.
I searching in this site a lot , but I can't find the circuit of this project.
