VBAT_SIM_800L.pdf
Power Supply for SIM800L
Adobe Portable Document Format -
4.78 kB -
06/03/2017 at 23:43
Preview
Fuente DC sin Transformador.pdf
Power supply without Transformer
4.33 kB -
06/03/2017 at 23:42
Preview
Detector_Frecuencia_Linea.pdf
Pcb design of the line frequency detector circuit
4.23 kB -
06/03/2017 at 23:41
Preview
Circuito de Control Solenoide.pdf
This is the design of the PCB that the control circuit for activation and desactivation to Solenoid valve.
3.82 kB -
06/03/2017 at 23:40
Preview
Buffer One Wire Uart.pdf
This is the design of the PCB for the buffer that is required when implement the 1-wire bus.
3.60 kB -
06/03/2017 at 23:39
Preview
1stTest_Temp_IR_LDR.rar
In this winrar package is the programming of the Nucleo 64 ARM card that controls the system shown in the previous image. The STM32CUBEMX software is used for the configuration and the ARM MDK keil IDE is used.
RAR Archive -
9.27 MB -
05/03/2017 at 22:32
Download
In this image has could see the components embedded in proto to test the 1st measurement. Here the system are measurement the ambient temperature, level of illumination and there are some infrarred barriers to protected the planting.
JPEG Image -
656.82 kB -
05/03/2017 at 22:28
Preview
In this image has could see connection between the nucleo 64 board and a 7-segment display in that could be seen to indicate the number of planting.
JPEG Image -
932.36 kB -
05/02/2017 at 00:23
Preview
JPEG Image -
932.36 kB -
05/02/2017 at 00:23
Preview
The system has been connected with the sensors to measurement the ambient temperature and the illumination of the planting. Through LM35 and LDR.
JPEG Image -
716.44 kB -
05/02/2017 at 00:23
Preview
JPEG Image -
637.20 kB -
05/02/2017 at 00:23
Preview
JPEG Image -
912.53 kB -
05/02/2017 at 00:23
Preview
JPEG Image -
669.64 kB -
05/02/2017 at 00:23
Preview
JPEG Image -
183.12 kB -
05/02/2017 at 00:22
Preview
JPEG Image -
92.49 kB -
05/02/2017 at 00:22
Preview
Description of the System Function (Hackaday.io).pdf
In this document has been detailed some characteristic and important topic for the project.
195.38 kB -
04/21/2017 at 15:06
Preview
IDE for develop the project.
Portable Network Graphics (PNG) -
41.11 kB -
04/21/2017 at 15:05
Preview
This software is to do the configuration of the board.
194.40 kB -
04/21/2017 at 15:05
Preview
JPEG Image -
147.15 kB -
04/21/2017 at 15:05
Preview
Air quality sensor to detect CO2 levels.
JPEG Image -
35.08 kB -
04/16/2017 at 02:04
Preview
SENSOR TO MEASURE COMPOST MOISTURE.
JPEG Image -
20.89 kB -
04/16/2017 at 02:04
Preview
This is the PinOut of STM32 Nucleo Board 64.
JPEG Image -
176.07 kB -
04/16/2017 at 01:59
Preview
JPEG Image -
183.02 kB -
04/16/2017 at 01:59
Preview
This will be activated when irrigation is needed.
JPEG Image -
52.12 kB -
04/16/2017 at 01:59
Preview
JPEG Image -
75.32 kB -
04/16/2017 at 01:59
Preview
This will be the wireless connection with the IoT page.
JPEG Image -
50.10 kB -
04/16/2017 at 01:59
Preview
Sensor to measure the humidity and temperature of the room.
JPEG Image -
32.26 kB -
04/16/2017 at 01:59
Preview
Sensor to measure the temperature in the compost of the plant.
JPEG Image -
19.36 kB -
04/16/2017 at 01:59
Preview
Sensor to measure the illumination.
JPEG Image -
15.92 kB -
04/16/2017 at 01:59
Preview
The IoT page where all the data is arrived.
5.31 kB -
04/16/2017 at 01:59
Preview
