Link to the bill of materials
A DIY polishing station to smoothen 3d-printed parts built using Arduino and portable humidifier.
DIY_Polishing_Station_v1.0.inoArduino codeino - 15.59 kB - 05/07/2023 at 17:14 |
polishing station - optimal position of humidifier.pngOptimal position of humidifier cover in relation to the polishing platform. This ensures that mist coming from humidifier will easily reach the platform. Also, being in the front (rather than the back) makes the mist more visible while polishing.Portable Network Graphics (PNG) - 36.64 kB - 04/08/2017 at 18:58 |
2017-04-08 - bulbasaur.jpgBulbasaur model printed using PolySmooth (Snow White) with 1.6mm wall thickness, polished for 35 mins. using 70% ethyl alcohol.JPEG Image - 6.37 MB - 04/09/2017 at 07:15 |
2017-04-08 - charmander.jpgBefore and after polishing: Bulbasaur model printed using PolySmooth (Snow White) with 1.6mm wall thickness, polished for 45 mins. using 70% ethyl alcohol.JPEG Image - 6.80 MB - 04/09/2017 at 08:03 |
platform.stlStandard Tesselated Geometry - 648.62 kB - 04/06/2017 at 05:27 |
2017-04-08
2017-04-07
2017-04-06
Must-haves:
Nice-to-haves:
2017-04-07
2017-04-06
2017-04-05
Hi, that seems awesome however could you explain more how it works? and how you use it (alcohol dosage? is it working on PLA or ABS or PETG?).... thanks
Can you please share a link about your 5V portable humidifier?
I am about to order the parts for this. Are there any updates I should be aware of? I will be polishing small and large parts- up to 6"x12". Great project! Thanks for your time.
