Improve CANable
07/09/2017 at 16:00 • 1 comment -
Add a platform
07/08/2017 at 14:17 • 2 comments -
A printable linear module for AnanasStepper
07/05/2017 at 14:57 • 0 commentsThis is a linear module designed for AnanasStepper -
3 axis platform and five brother
07/02/2017 at 14:23 • 0 comments -
Beaglebone Black with CAN
06/22/2017 at 14:48 • 0 commentsThere is CBB serial board may you need
https://docs.google.com/document/d/1sgurQ-7gLyn7g-Kg983NRM0aDkYEqHqy9dmrieX_RUM/edit#
I do the test with a simple module
Here is a canbus-beaglebonehttps://github.com/digitalbond/canbus-beaglebone
That may help you with set up CAN bus with Beaglebone Black
The import things that you should disable HDMI
add
capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN
to
/boot/uEnv.txt
Run Raspberry With CAN bus(MCP2515)
06/22/2017 at 03:05 • 0 commentsDrive Raspberry with CAN.
It is recommended to use The lastest system of Raspberry!
As I tested, the max bitrate of CAN can be 500Khz.
Reference Material.
https://www.raspberrypi.org/forums/viewtopic.php?t=141052
http://tiqni.com/raspberry-pi/can-bus-support-in-raspberry-pi
http://skpang.co.uk/blog/archives/1165
Some Problem and Answer:
https://www.raspberrypi.org/forums/viewtopic.php?f=28&t=155651&p=1023355#p1023355
Find a nice project -CANable USB-CAN adapter
06/17/2017 at 15:17 • 0 comments -
Linear Module for AnanasStepper
06/14/2017 at 14:29 • 0 comments -
AnanasStepper has a webpage!
06/12/2017 at 05:54 • 0 commentsThere will be the homepage of AnanasStepper
Release Hardware
06/08/2017 at 14:38 • 1 commentAnanasStepper2.0-hardware
This is the hardware part of AnanasStepper2.0
This hardware is compatible with https://github.com/Dark-Guan/AnanasBoard Drive should be set for 3.3V
