« Back to project details
First Test
04/15/2017 at 11:51 • 1 comment -
Track
04/15/2017 at 11:44 • 0 comments -
The Strip
04/10/2017 at 06:25 • 3 comments -
First version
04/10/2017 at 06:22 • 0 commentsBefore the closed loop version the previous version of the display had two strips wound around a single tube (bit like a cassette tape) with a gear in the middle to drive it. I thought the tension wouldn't be much of a problem considered its a fairly short strip, but at the ends of the strip it was to tight.
