Goofing around with the new ESP32 module
Please forgive this messy code, I was just goofing around and did not plan on sharing it, but here I am sharing it. LOL
#include <WiFi.h> const char* ssid = "(Your WiFi Access Point Name)"; const char* password = "(Your WiFi Access Point Password)"; int ledPin = 4; WiFiServer server(80); //---------------------------------- #include "esp32-hal-ledc.h" uint32_t maxint = 65535; uint32_t servoMax = 8000; uint32_t servoMin = 1700; uint32_t servoLow = servoMin; //1700 + 1300; uint32_t servoHigh = 1700 + 1000 + 1300; //servoLow+1000; uint32_t servoCenter = (servoLow + servoHigh) / 2; const byte numberOfServos = 12; byte servoPins[numberOfServos] = {5, 12, 13, 14, 15, 16, 17, 18, 19, 21, 22, 23}; char command = 0; void setupServo() { for (byte servoIndex = 0; servoIndex < numberOfServos; servoIndex++) { byte channel = servoIndex; byte servoPin = servoPins[servoIndex]; ledcSetup(channel, 50, 16); // channel X, 50 Hz, 16-bit depth ledcAttachPin(servoPin, channel); // GPIO servoPin on channel X ledcWrite(channel, servoHigh); //servoMin } delay(2000); } //---------------------------------- void setup() { Serial.begin(115200); pinMode(ledPin, OUTPUT); // set the LED pin mode delay(10); // We start by connecting to a WiFi network Serial.println(); Serial.println(); Serial.print("Connecting to "); Serial.println(ssid); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(500); Serial.print("."); } Serial.println(""); Serial.println("WiFi connected"); Serial.println("IP address: "); Serial.println(WiFi.localIP()); server.begin(); setupServo(); } void Marching() { for (byte servoIndex = 0; servoIndex < numberOfServos; servoIndex++) { byte channel = servoIndex; ledcWrite(channel, servoHigh); } delay(500); for (byte servoIndex = 0; servoIndex < numberOfServos; servoIndex++) { byte channel = servoIndex; ledcWrite(channel, servoLow); } delay(500); } void LeftToRight(int servoValue, int dly) { for (int head = 0; head < numberOfServos; head++) { if (head >= 0 && head < numberOfServos) ledcWrite(head, servoValue); delay(dly); } } void RightToLeft(int servoValue, int dly) { for (int head = numberOfServos - 1; head >= 0 ; head--) { if (head >= 0 && head < numberOfServos) ledcWrite(head, servoValue); delay(dly); } } void SpreadOut(int dly) { int half = (numberOfServos / 2); for (int i = 0; i <= half ; i++) { int left = half - i; int right = half + i; if (left >= 0 && left < numberOfServos) ledcWrite(left, servoHigh); if (right >= 0 && right < numberOfServos) ledcWrite(right, servoLow); delay(dly); } } void SpreadOutRestore(int dly) { int half = (numberOfServos / 2); for (int i = 0; i <= half ; i++) { int left = half - i; int right = half + i; if (left >= 0 && left < numberOfServos) ledcWrite(left, servoCenter); if (right >= 0 && right < numberOfServos) ledcWrite(right, servoCenter); delay(dly); } } void OutIn(int dly) { int half = (numberOfServos / 2); for (int i = 0; i <= half ; i++) { int left = (numberOfServos - 1) - i; int right = i; if (left >= 0 && left < numberOfServos) ledcWrite(left, servoCenter); if (right >= 0 && right < numberOfServos) ledcWrite(right, servoCenter); delay(dly); } } int value = 0; void SendHtmlResponse(WiFiClient client) { // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK) // and a content-type so the client knows what's coming, then a blank line: client.println("HTTP/1.1 200 OK"); client.println("Content-type:text/html"); client.println(); // the content of the HTTP response follows the header: client.print("<h1 style='font-size:400%;'>"); client.print("<a href='/'>Home</a><br>"); client.print("Left to Right: <a href='/A'>\\\</a> <a href='/B'>///</a><br>"); client.print("Right to Left: <a href='/C'>\\\</a> <a href='/D'>///</a><br>"); client.print("All: <a href='/E'>\\\</a> <a href='/H'>Center</a> <a...
View project log
Awesome demo Hari. I have completed many projects with the esp8266 and look forward to working with the esp32
ziggurat29
stefan.schnitzer
Santo_mar_d_velaz
Paul Scott
Yes, delete it Cancel
You are about to report the project "HariFun #150 Playing with ESP32", please tell us the reason.
