Counting circuit consists of modified astable multivibrator circuit with three NAND, master-slave data flip flops connected as series toggle flip flops, thus I have 4-bit counter. The dtl gates have LEDs instead of pairs of conventional diodes to slightly save on part count and cost. In addition, this scheme provides visuals for gate working.
Pavel
collector of Q1 was wired directly to base of Q2, to achieve second inversion, thus making buffer; simultaneously from the same collector was the tap to the AND gate of decoder, as inverted input. Failed. the solution was to make this into two full-fledged invertors, and after this modification all started to work as it was intended to.
Eric Ljungquist
Dylan
Jeroen Brinkman
Someday, maybe) First, I have to learn how to use quartz oscillator though. And full-fledged clock will consume much more parts, time and effort.
