The Decimal Counting Unit or DCU can be modified for 24 hour format
The logic module contains the wave shaper and divide by 60 circuit for line frequency timing, seconds count, set control, divide by 6 for tens minutes and 13th hour reset and simple power supply.
I use point to point wiring to retain the spirit of 'home brew' building.
I worked out the remaining bugs this month.
I will be posting some additional photos soon.
