HAVE A QUESTION OR NEED HELP?
04/17/2017 at 06:59 • 0 commentsIf you have a question or just don't know please feel free to ask as many questions as you need I will help you the best I can. Remember there are no dumb questions. Just dumb answers. I do ask you to do the following thing before you ask.
TRY TO GOOGLE IT FIRST. I'm going to call you out or just plain out ignore you. If you ask " Hey what does sPOE mean? ". And I google it and the very first thing that pops up is. " Definition of sPoE. sPoE, an abbreviation for simplified Power Over Ethernet, PoE technology lets network cables carry electrical power in addition to data, making surveillance easier and more affordable. ... ※A power connection, to deliver the electrical power to the camera." Everybody is here to learn and help. NOT do it for you.
Next thing try to be as detailed as you can. That means What is it your working on? Device? Model? Verison? Build? What are you using to work on it with? What exactly is it that you do you not know? What or how did you try it? What exactly happened when you tried to do whatever? What exactly was you expecting or wanting to happen?
Last thing Screenshot everything. If you can't or don't know how. everybody has a cell phone these days take a picture it that way. Ever heard "A picture is worth a 1000 words"? Then try it...
The short of it is it's better to be over explained than unexplained.
I'm gonna try to figure at a good place to handle question. Asoon as i can figure out what works best. I don't know maybe I will make a FAQs Page or something. For right now tho post them in the DISCUSSIONS section at the bottom.
** KEYWORD & SYMBOL DEFINITIONS **
04/17/2017 at 03:51 • 0 comments** KEYWORD & SYMBOL DEFINITIONS **
SYMBOLS
[ ! ] CAUTION or RISK. Be careful what with what you are doing. There is a risk of damage. Or detrimental effect toward wanted outcome.
[ * ] USEFUL TIP This is just a little extra information on the subject. That someone thought you might could use.
[ ** ] URL or WEB ADDRESS Anything with this symbol beside it. Will be listed on the RESOURCE PAGE under the "Project Log Entry" section.
KEYWORDS
- IP Camera An Internet protocol camera, or IP camera, is a type of digital video camera commonly employed for surveillance, and which, unlike analog closed circuit television (CCTV) cameras, can send and receive data via a computer network and the Internet.
- Security System A control panel, which is the primary controller of a home'ssecurity system. Door and window sensors. Motion sensors, both interior and exterior. Wired or wireless security cameras. A high-decibel siren or alarm.
- WIFI Connection Wi-Fi is the name of a popular wireless networking technology that uses radio waves to provide wireless high-speed Internet and network connections. A common misconception is that the termWi-Fi is short for "wireless fidelity," however this is not the case.Wi-Fi is simply a trademarked phrase that means IEEE 802.11x.
- Wired Connection A wired network is a common type of wired configuration. Most wired networks useEthernet cables to transfer data between connected PCs. In a small wired network, a single router may be used to connect all the computers. Larger networks often involve multiple routers or switches that connect to each other.
- NVR A network video recorder (NVR) is a software program that records video in a digital format to a disk drive, USB flash drive, SD memory card or other mass storage device. An NVR contains no dedicated video capture hardware.
- DVR Short for (Digital Video Recorder) A device that records video from up to a dozen or more surveillance cameras onto a hard disk. ... Digital recorders are more flexible than earlier analog VHS tape systems, and the video can be easily transmitted over a computer network.
Dr.Query
