I know it doesn't look like much, but it's my first proof that my architecture is valid. After more struggles with my software tools, I was finally able to connect to the Cmod board and download. My first successful download gave me this output. There were a lot of things that needed to go right, but I guess I took care of them beforehand. I wasn't sure the clock was set right, and my UART needed to be running at the right speed, etc.
My program loaded the value 35 into ALU A, subtracted 3, and moved the result to the UART. This gives me the value 32 which is ASCII 2. I didn't have a stop to the program, so I think it's wrapping around the whole memory space and executing the code again and again. Fortunately, my program is set up so that a command of all zeroes will do nothing (MOV TRASH -> TRASH).
If you don't mind writing a bit of C, the asl assembler (http://john.ccac.rwth-aachen.de:8000/as/) is an extensible assembler - I modified it to be able to generate code for my computer project
Wow this supports A LOT of processors. And you've already had success with it...
Yep, it's quite well documented, and reasonably easy to add support for a new processor
Good work! It's a good feeling when it all 'comes together' :)
Hi, nice project! Congrats on your "Hello 2" test program. One idea for an assembler is to use SMAL32 (see http://homepage.divms.uiowa.edu/~jones/cross/smal32/ ). It is a generic assembler with a simple macro language that makes it fairly easy to add "instructions" for custom CPUs (and for your CPU, mostly just need to define the special memory locations, I would think). For an example of its use, see the MCPU at https://github.com/cpldcpu/MCPU (this is another project using a nifty 4 instruction tiny computer in VHDL/Verilog).
Cool, I will definitely check this out.
Congratulations !!!
Thanks!
