One thing that's been very annoying in coding is how I interface to the memory. I have a 16-bit page register that allows me to access 128 memory locations with the source/destination bus. So when I push/pop I have to change my memory page to the stack. Then I lose access to my other variables. Copying a variable onto the stack is tough because I have to store it in the few registers I have, change the memory page, and then copy it back without disturbing those registers.
I would really like to be able to access the whole 16-bit memory at any time. The old 6502 allows you to access the whole 16-bit memory space and I'm jealous. This would let me pop/push without losing access to my other memory space. I can move variables onto the stack easily. And I can transfer from anywhere to anywhere in my memory very easily.
Implications:
So the memory map will look something like:
0x0000 | 0x00FF | Function Registers |
0x0100 | 0x7FFF | ROM |
0x8000 | 0xFFFF | RAM |
- Each instruction now goes from 16-bits to 32-bits. So my programs increase in size pretty quickly.
- I'll have to rewrite all the code I previously wrote.
- The new instruction cycle would be two fetches for the source address, copy the source data to a temporary register, two more fetches for the destination, then write the temporary register to the destination - 6 clock operation. Boy this went up fast from my original desire for 1 clock per instruction!
- I won't need a LOAD register anymore. It will be trivial to put a 256 constants in the ROM and do a transfer from there. This removes all the LOAD register chips.
- The pointer address register will have to change to point to a 16-bit address, so a HI and LO register.
- I'll have to change the boot vector to 0x0100.
- I'll have to decode a 16-bit address now, but maybe I can just check if the upper byte is all zeros.
This is almost a complete tear-up of the design. However, it will be much easier and elegant to code for this CPU (and more fun). And I don't think it will increase the chip count
