I've completed the hardware and software updates for the 16-bit register address bus. I now have the monitor program running (not really a bootloader which I've been calling it). I have also updated my PUSH/POP commands along with my CALL and RETURN commands. So my stack is working correctly again. I also implemented putting variables onto the stack and using them in functions. The first function I put into the ROM is the BinaryToASCII function. I push a byte onto the stack, and then call it. It converts the byte into two ASCII bytes which it then sends over the UART. I made this function so I can use it in my monitor program to read memory locations and display them.
I've found coding goes much faster now with the new architecture. There's a lot less mental gymnastics. This makes it a lot more fun to code for it as well.
