I have all of the CPU working now with the exception of the UART. My BREAK command is working, which makes it much easier to check out the functions. I just run the clock fast until it hits the BREAK command, and then I can step through the next instruction. Now, I just need to get the UART working so I can load programs over that port to the RAM directly. So close!
