Got the data, da-bu-dy-de-code!
05/03/2017 at 03:55 • 0 commentsAfter renaming HC-05 to VC99, bluetooth serial port in OSX was /dev/cu.VC99-DevB
By launching serial motor, Arduino IDE connects to Bluetooth, HC-05 switch from fast to slow blinking indicating connection. QtDmm was not able to establish connection to HC-09. It would say connecting, blink rate would change, but did not work out of the box
Switch on rs232 on VC99 now or even before establishing connection
Process incoming data, log, display in a browser.. todo decode the rest of the.
The digits and polarity clearly visible, need to work out the rest of the bytes, suggested protocol was VC820 14 byte binary, this might be a good start http://www.mtoussaint.de/cdmm/doc/html/classVC820.html
Open & Solder
04/21/2017 at 18:40 • 0 commentsMaybe I should have soldered to the pcb, in case of an accident...
As seen in the last photo, there are 4 holes for holding the dial, do not undo them to keep the dial in place :D
Cleaning the contacts could also be good a idea, since it is open :D
