pin header
05/27/2017 at 14:56 • 0 commentspins pushed through and plastic sanded to conform to the remaining space next to the battery holder (you might need to melt the solder and push it inwards as hard as you can without hurting yourself), then soldered from the top.
Not the best way to do it but this way you still have solder access to the pin header on the top (for possible mods)
SPI SRAM job
05/27/2017 at 10:18 • 0 commentsThe SPI SRAM package fits... sort of. The pins are bent down ever so slightly. One side can be soldered with the oxide skin snot technique, for the other side I've used THT resistor leads. Solder them to the pins, trim and repeat. When all are soldered, add a bit of flux and reflow with hot air to make sure the connections are good. Nudge with pliers if needed.
Pin 1 is left floating (CS).
list of modifications
05/27/2017 at 10:06 • 0 commentsI've made the a-priori list of modifications to get this bodge working:
I2C is routed to the DAC via the extension header. Works for me.
SPI SRAM: spiram.c says the following about the choice of peripheral chip select:
//select HSPI CS2 ,disable HSPI CS0 and CS1 CLEAR_PERI_REG_MASK(SPI_PIN(HSPI), SPI_CS2_DIS); SET_PERI_REG_MASK(SPI_PIN(HSPI), SPI_CS0_DIS |SPI_CS1_DIS);
but SPI_CS1 and SPI_CS0 are interchangeable and all hardware chip select pins should be shared among the SPI transceivers. With GPIO0 already taken, the next best thing (and the only remaining one) is SPI_CS1 on GPIO1 / U0TXD. the CS might have to be or-ed with an output expander level to block SRAM after start-up and in config mode - it may also be hooked to the RX side of the usb serial chip so it can be driven high by an I2C slave chip on the add-on board as long as the 470R * SRAM CS input capacitance time constant penalty does not mess up SPI timing.LCD:
now it gets dirty. The display gets its own SPI channel to profit from DMA. Otherwise high frame rates wouldn't be possible. This lends itself to occupying a dedicated chip select pin. The display controller ILI9163C accepts a stream of frames and once initiated, it does not need CS interaction, allowing the LCD CS to be bit banged at the start of a new frame. I've seen the display glitch and stop updating, so maybe "only once" is not the best idea. Bit-banged CS toggle (low-high-low) to initiate a frame transfer seems legit.
GPIO15is not easy to access. There are however two points (a scraped via and a passive component pad) from where the LCD CS trace and, once cut on the bottom side, GPIO15 from the ESP8266 can be accessed. GPIO5 is conveniently routed to the mechanical switch. GPIO5 is also routed to the top side of the board where it is gated by IR_EN (U1A) so as long as IR_EN is off, GPIO5 is fine. This can be reverted by soldering a 0R resistor on the ends of the trace.To avoid loading the 3.3V rail and to get the best performance, the class D PA power is supplied directly from VBAT (canidate terminals shown). Connecting a device to VBAT does not conflict with the battery protection circuitry and reverse bat switching because the entire BAT- (GND) rail is being disconnected.
Before I get into doing the layout, two things have to be demonstrated:
- LCD function recovery
- SRAM access works
- SRAM does not interfere with serial firmware upload
Strategy for delivery
05/25/2017 at 18:21 • 0 commentsSince PCBs aren't done yet (didn't have the time, sorry) I'd be happy to provide core part kits (SRAM, DAC, audio jack) along with envelopes which you can label to receive a PCB as soon as they arrive.
Leave in the DAC if you want the PCB shipped with that QFN part assembled.
Availability: Saturday (check back here to get an update)
