Evolution into O;TL
03/20/2017 at 21:04 • 0 commentsWe are parking this project while we iron the new design we are working on in the Obsolete Time Lite Project!
USB power, WiFi, atmospheric sensing... all that in an ALTOIDS tin!
https://hackaday.io/project/20439-obsolete-time-liteSupport the project by giving it a "Like" !
More unsuccessful PSU
02/28/2016 at 15:58 • 0 commentsWe are at it again, prototyping a new power supply. Not yet 100% successful but I feel we are getting closer.
If anything it is getting smaller!
Beauty shot!
11/01/2015 at 01:10 • 0 comments![]()
Update, finally!
08/11/2015 at 13:27 • 0 commentsWe have been working on a new power supply for the clock. More efficient and would make USB power possible.
And here is how we make PCBs using the laser cutter, we coat the bare copper with mat black paint and etch it off. The rest is like traditional toner transfer method using etching solution to get rid of the unwanted copper.
More cases!
03/06/2015 at 19:45 • 0 commentsWorking with wood is difficult... but I believe we are getting there.
Next up, bamboo! Stay tuned.
First Laser Cut Case
12/15/2014 at 00:28 • 0 commentsFirst case cut using a laser cutter. The result is pretty good, looking forward to try with good wood. Stay tuned.
Blender Render!
12/05/2014 at 01:37 • 0 commentsMatt is doing amazing things with a program he only just picked up!
The magic of Bluetooth
11/19/2014 at 02:37 • 0 commentsA desk clock with no buttons... Setting time using nothing other than a magnet...
What if you had a full control panel on your favorite smartphone to set time directly from the internet, adjust brightness, start a countdown timer so your pizza doesnt over cook (trust me, it happens), change 12-24 hour time format etc?
Here is the first draft of the app as working a proof of concept.
SWAMP Fest Swansea
10/16/2014 at 19:16 • 0 commentsLast weekend we went to showcase O;T at a Swansea (Wales UK) hackspace ran event. It was very good to get feedback from the general public.
It was great to see the reactions when pointing out that nixie tubes are made up of layers. I guess there isnt anything like that anymore with flat "modern" displays.
Having the prototype was great, the best was probably, and I quote:
""How did you fit all this into there?""
Thank Swansea Hackspace for having us!
Lights ON!
10/08/2014 at 00:20 • 0 commentsBoards are populated and after some debugging and adjustments (cold solder joint oops) it lights up!
It is great to see the driver board fit nicely in the case. For now the controller board is sitting outside for convenience but will be moved inside after the software debugging is finished.
More updates updates and good pictures very soon.
opeRaptor
