21Add tape
Use a piece of two-sided tape to hold the battery in place, to prevent it from shorting the matrix pins, and to protect it from being damaged by the sharp pin leftovers sticking from the board.
22More tape
Also add some tape on top, to prevent shorts on the Feather side.
23Finished
The board is finished and ready to be programmed.
