BlackRock SDR: BeagleBone SDR cape
HF Rx SDR cape for the BeagleBoneBlack based on the SoftRock RXII
HF Rx based on the SoftRock Ensemble RXII.
Essentially you take the proven design of the softrock, remove the audio interface and go direct to a decent ADC, and feed that into a beaglebone black linux board for all the end processing.
Details are super light because I haven't got very far in the design process yet.
Essentially I want to do this design the 'open source' way; I'll take a proven design (SoftRock), build on it from various community sources (KD2BOA, M0RZF), and add a bit of my own stuff in there (BBB).
This is my first analog RF design, and although I'm an electrical engineer by trade I would like to not have 10 revisions before I get something working. So in that vein a proven design is very important to me. At the same time I think there is a massive hole in current portable HF SDR offerings. Using the BBB one can really leverage the processing power and linux software world to build what I think will be an awesome little HF receiver.
The idea then would be to get HF Rx working and move onto Rx/Tx. That's the future plans anyway.
Project Intro Video is up!
  • Schematic updates
    eresonance10/19/2014 at 20:25 0 comments
    I finally have time to work on my project! I've updated the schematics a bit and am probably about 50% finished.
    The ADC I picked out can only do 4Mbps with two channels instead of the 8Mbps that I was aiming for. I may still go with it since 4 is decent but we'll see.
    There were also a number of improvements that I was looking at, but I want to try and limit the risk involved in these so we'll see what I come up with. One thing that would be awesome is something like the antenna analyzer from the PortableSDR (https://hackaday.io/project/1538-PortableSDR) since the circuit for that is particularly simple. Not 100% sure how to fit it in there as I don't have a Tx path and mux, but it shouldn't be too hard to add one. My major concern is all the frontend loss since there are quite a few muxes. May even try to look at a RF relay, one that's normally closed for the Rx path.
  • ADC
    eresonance08/21/2014 at 00:35 0 comments
    Ohhhh ADCs, it's always annoying looking through all the specs to find the perfect one.
    I've spent quite a bit of time digging through websites to find an ADC that's not bad. Something that's good at what it does but not over-the-top. What I've come up with is the THS12082, a 12bit dual-channel 8MSPS ADC with a FIFO and a parallel interface. For a TSOP part it's almost $19, so it's not exactly cheap, but I think aside from the BBB the total part cost won't be outrageous. Not that the BBB's price is outrageous, but you know what I mean.
    This ADC seems quite good. It will be able to sample both the I and Q signals at a very reasonable rate with a good amount of precision. The FIFO relaxes the requirements for needing a perfect PRU implementation (however I'm not too worried about that). The parallel interface eases signal integrity issues going through the BBB headers. So yeah, I think it will do an admirable job.
    Now I just have to worry about the op-amps and the amplifier circuit.
  • Design Decisions
    eresonance08/21/2014 at 00:23 0 comments
    So from the system design doc you can see a few important details:
    First off the stand-alone circuitry for the quadrature clock generation remains from the softrock. I had thought about using the BBB to do it however there were multiple people online that have complained about doing it that way. I think one of the issues is that the BBB digital IOs were designed nicely to interface with digital logic, however the quad-clk-gen is clocking what is essentially an analog circuit. Things like noise and uniform phase are important here. So since it's a fairly proven design and there are not too many complaints about it I think it will be fine to keep it.
    The other point to make is with the devices used for the muxing and QSD; the FST3253. Doing a fairly large search through all of the muxes I could find was unproductive; it seems that there aren't too many devices out there that do a better job than this part. I dislike that it's 5V only, but that's not a big deal. M0RZF noted that there may be a better alternative in the TS3A5017 so I'll have to compare and make a choice between the two. Otherwise they are both pretty similar.
    Along this vein there is a whole lot of research here:
    http://martein.home.xs4all.nl/pa3ake/hmode/index.html
    But to be honest it's a lot to look through so I think I'll just design in an I/Q 'squarer' as recommended by M0RZF. In this case it's just a buffer that will minimize phase disturbances in the QSD. That is, it will cause the QSD to switch in the same points in the rising edge of the clock every time. Makes sense conceptually, but I'm not a pro at this stuff :)
  • System Design Document Up!
    eresonance08/20/2014 at 23:24 0 comments
    I made this block diagram a while ago but it was pretty terrible, so I redrew it tonight and finally got it up.
    n the diagram you see that it's very similar to the softrock Rx II (diagram here). Essentially the beaglebone black (BBB) controls the local oscillator frequency, 'superband' filter selection, and reads the raw I/Q values from the ADC. It replaces the requirement for a separate uctrler and soundcard, and should be pretty easy to use through the use of the PRU on the TI chip in the BBB.
  • Updates (read: slowly stop being lazy)
    eresonance08/11/2014 at 02:28 0 comments
    Ok, got the first bit of project files on github. I'm a big fan of git but I really dislike windows for development. Git on windows command prompt is very annoying...
    Anyways, the general idea is use some of the beaglebone experience from Jim Kleiner and his PRJ123 ADC board he made here:
    http://kd2boa.blogspot.ca/2013/12/normal-0-false-false-false-en-us-x-none.html
    And generally base the SDR bits on the softrock, found here:
    http://www.wb5rvz.org/ensemble_rx_ii/index
    I would like to make some improvements to the softrock based on some of what Jim has done and what Robert Brown (M0RZF) has done with his unity SDR project (http://www.m0rzf.co.uk/softrock7/index.html). However the deadlines are tight and I don't want to mess something/everything up so I'm going to play this one conservatively.
    Ideally once I get the Rx board working I'll either make a separate board for Tx or I will try to cram the Tx onto an upgraded Rx/Tx board. But that's way down the road. For now, it's all about the Rx. Sweet sweet HF Rx.
View all 5 project logs
Richard P wrote 12/19/2015 at 18:29 point
On the DAC/ADC, the PCM3060 is quite inexpensive at £4.50 ($6) or there about. Its Serial clocked and can run up to 96Khz sample rates. The PeaberrySDR uses this connected to a Cypress USB Audio adapter (The Peaberry performs quite well)
Shane Short wrote 11/02/2014 at 13:29 point
I'm looking to make an adsb receiver using the pru on the bbb, perhaps we should compare notes :)
bibilukaa wrote 08/23/2014 at 08:19 point
Another interesting project on the theme of SDR. Please more details when will be ready. To use some proven concepts like ensemble rx II it is good approach.
Thanks for sharing...
Tino
eresonance wrote 08/21/2014 at 00:44 point
Oh yeah, and a huge shout out to Jim Kleiner, who was gracious enough to give me his kicad design files for his PRJ123: http://kd2boa.blogspot.ca/
Kicad doesn't make it easy (or even possible?) to copy and build upon them, but at the very least I'll be copying the PCB dimensions and a few other placements to ease the layout side of things.
He's done a lot of work with the BBB and his cool little radio project, go check it out!
